Knowledge Base Article
How do I implement and connect between an external Altera_PLL and an ALTLVDS_RX with Dynamic Phase Alignment (DPA) enabled?
Description
When using ALTLVDS_RX in external PLL mode with DPA enabled in Quartus® II software versions 12.1 and later, you will receive an error in Analysis and Synthesis as shown below:
Error: SERDES DPA Block node \'lvds_rx:lvds_rx_inst0|altlvds_rx:ALTLVDS_RX_component|lvds_rx_lvds_rx:auto_generated|lvds_rx_dpa3\' is not properly connected on the \'DPACLKIN\' port. It must be connected to one of the valid ports listed below.
    Info: Can be connected to PHOUT port of arriav_pll_dpa_output WYSIWYG
    Info: Can be connected to OUTCLK port of generic_pll WYSIWYG
This affects Arria® V and Stratix® V devices.
Resolution
Modify your design when using the ALTLVDS_RX megafunction in external PLL mode with DPA enabled by downloading this How-to document and example-project.zip file.
First, you will need to complete the steps for implementing ALTLVDS_RX and ALTLVDS_TX with external PLL mode as described in the related solution below.
Related Articles
Updated 4 months ago
Version 4.0
