Knowledge Base Article
How do I disable the transceiver On-Chip-Termination (OCT) of the Stratix IV GT device 10GBase-R PHY IP?
Description
You can disable the transceiver On-Chip-Termination (OCT) of the Stratix® IV GT device 10GBase-R PHY IP by following the steps below.
  1. Open the MegaWizard™ generated siv_xcvr_low_latency_phy_nr.sv file.
  2. Search for the "tx_use_external_termination" and "rx_use_external_termination" parameters and change the setting from FALSE to TRUE.
  3. Recompile your Quartus® II software project and verify the transceiver pin termination in the fitter report.
Updated 11 months ago
Version 3.0
