Knowledge Base Article
How do I configure the Intel® Quartus® Prime Pro software to use an Intel Enpirion® EM22x device as a SmartVID Power Management Controller for Intel Stratix® 10 devices?
Description
Intel® Enpirion® EM2260 / EM22xx parts can be used as Power Management Controllers for SmartVID enabled variants of Intel Stratix® 10 devices. Follow the instructions below to configure the Intel Quartus® Prime Pro software for this use case.
Resolution
In the Device and Pin Options dialog box in Intel Quartus Prime Pro Software, under Power management and VID tab select :
- Bus Speed mode : 100 KHz / 400 KHz
- Slave Device type : Other
- PMbus Device X Slave address : Set the PMbus address in hex without the '0x' prefix
- Voltage Output format : Linear
- Intel Enpirion devices only support Linear mode
- If Auto Discovery is selected, set the direct coefficients m/b/r to 0
- Linear format N : -13
- Translated voltage value unit : Volts
- Enable PAGE command : Leave this disabled (Default)
- Intel Enpirion devices do not support PAGE command
Updated 1 month ago
