Knowledge Base Article
How do I compile an OpenCL kernel using the latest version of the Intel® SDK for OpenCL™ with a Board Support Package (BSP) from a previous version?
Description
Beginning with Intel® SDK for OpenCL™ and Intel Quartus Prime Pro version 18.1, it is possible to compile an OpenCL™ kernel using the latest version of the Intel® SDK for OpenCL™ while using a BSP compiled with a previous version. However, the Quartus Prime software version that matches the version of the BSP must also be installed and used .
Resolution
·        Set environment variables to point the Quartus Prime version that was used to compile the BSP.
·        Set the environment variables to point to the BSP directory.
·        Set environment variables to point to the latest version of the Intel SDK for OpenCL.
·        Run the Intel® SDK for OpenCL™ initialization script.
·        Compile the kernel.
·        Run the design using the latest version of the Intel SDK for OpenCL or Intel RTE for OpenCL.
For example, if you have a BSP from version 17.1, and you want to use the Intel® SDK for OpenCL™ version 18.1, you must have version 17.1 of the Quartus Prime software installed and you must set the environment variables as shown in the following scripts.
Notes:
Change the directories in the script to match your installation.
Make sure there are no other versions of Quartus or the Intel® SDK for OpenCL™ in the path.
Linux (mixed_compile.sh)
# *** Set QUARTUS and QSYS 17.1 ***
export QSYS_ROOTDIR=/IntelFPGA_pro/17.1/qsys/bin
export QUARTUS_ROOTDIR=/IntelFPGA_pro/17.1/quartus/bin
export QUARTUS_ROOTDIR_OVERRIDE=/IntelFPGA_pro/17.1/quartus/bin
export PATH="/IntelFPGA_pro/17.1/quartus/bin/:$PATH"
export PATH="/IntelFPGA_pro/17.1/qsys/bin:$PATH"
# A10 ref BSP version 17.1
export AOCL_BOARD_PACKAGE_ROOT=/IntelFPGA_pro/17.1/hld/board/a10_ref
export PATH="/IntelFPGA_pro/17.1/hld/board/a10_ref/ip/:$PATH"
# set OpenCL version 18.1
export ALTERAOCLSDKROOT=/IntelFPGA_pro/18.1/hld
export INTELFPGAOCLSDKROOT=/IntelFPGA_pro/18.1/hld
#run the OpenCL Setup script in 18.1
source /IntelFPGA_pro/18.1/hld/init_opencl.sh
Windows  (mixed_compile.bat)
rem *** Quartus and Qsys 17.1 ***
set QSYS_ROOTDIR=c:\IntelFPGA_pro\17.1\qsys\bin
set QUARTUS_ROOTDIR=c:\IntelFPGA_pro\17.1\quartus
set QUARTUS_ROOTDIR_OVERRIDE=c:\IntelFPGA_pro\17.1%\quartus
set path=%path%;c:\IntelFPGA_pro\17.1\quartus\bin64;
set path=%path%;c:\IntelFPGA_pro\17.1\qsys\bin;
rem *** A10 BSP 17.1  ***
set AOCL_BOARD_PACKAGE_ROOT=c:\IntelFPGA_pro\17.1\hld\board\a10_ref
set path=%path%;c:\IntelFPGA_pro\17.1\hld\board\a10_ref\ip;
rem *** OpenCL SDK 18.1 ***
set ALTERAOCLSDKROOT= c:\IntelFPGA_pro\18.1\hld
set INTELFPGAOCLSDKROOT= c:\IntelFPGA_pro\18.1\hld
%INTELFPGAOCLSDKROOT%\init_opencl.bat
To verify the configuration is correct, run the following:
(Linux)
$cd /IntelFPGA_pro/18.1/hld/board/custom_platform_toolkit/tests/boardtest
$aoc boardtest.cl
(Windows)
> cd c:\IntelFPGA_pro\17.1\hld\board\custom_platform_toolkit\tests\boardtest
> aoc boardtest.cl
If the configuration is correct, the following message should appear after compilation.
     aoc: Hardware generation completed successfully.
Updated 11 months ago
Version 3.0
