Knowledge Base Article
How do I build an Altera DS-5 project without semi-hosting?
Description
Due to a problem in Altera SOS EDS version 13.0 and 13.1, the  Assembler code required to build a non semi-hosted application is missing.
Resolution
To work around this problem follow the steps below to download the required Assembler file and then update your linker script to disable semi-hosting.
An example Makefile and Linker script based on the Altera-SoCFPGA-HardwareLib-GNU.tar.gz example from SOC EDS 13.0Sp1 can be downloaded from the link below: ExampleFiles_nonSemiHosted.zip (altera-socfpga.ld, Makefile, reset.s)
Steps to enable non-semi hosted application using Altera Example as template
  1. Download reset.o:ExampleFiles_nonSemiHosted.zip
  2. Copy / backup your existing Altera linker script altera-socfpga-hosted.ld
  3. Change the compile flag
    Before: -lcs3hosted
    After: -lcs3unhosted:  GROUP(-lgcc -lc -lcs3 -lcs3unhosted -lcs3arm)
  4. Comment out or remove the following code sections:
    /* Enable arm semihosting */
    EXTERN(__auto_semihosting) /* force exit to be picked up in a hosted or os environment */
    EXTERN (exit atexit)
  5. Update Makefile to compile reset.o and point to updated Linker Script from steps 2-4
    #Assembler Flags
    AFLAGS := -g -O0 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -x assembler
    #Assembler source files
    A_SRC := reset.s
    #Original Linker script
    #LINKER_SCRIPT := altera-socfpga_hosted.ld
    #Link to updated linker script for non-semihosted
    LINKER_SCRIPT := altera-socfpga.ld
    #Clause to compile reset.o
    reset.o:
      -c reset.s -o reset.o
    #Updated linker line to add dependency for reset.o
    : reset.o
      -T reset.o -o
      -d > .objdump
      > .map
Note:  When editing Makefiles ensure correct Tab and Space rules are followed
This problem fixed beginning with the SOC EDS version 14.0
Updated 4 months ago
Version 4.0
