Knowledge Base Article
How can the Intel Arria® 10 EMIF IP example design traffic generator be modified for a fixed data pattern?
Description
When generating an Intel® Arria® 10 EMIF example design, a traffic generator is implemented with a pre-defined PRBS traffic pattern. For further debugging, it may be useful to use a fixed data pattern.
Resolution
The default PRBS data pattern is implemented using a LFSR (Linear Feedback Shifting Register), which is located in the altera_emif_avl_tg_lfsr_wrapper.sv file. Comment out the original code and change it to the data pattern that you require (see example below).
//   generate
//      genvar i;
//      for (i = 0; i < NUM_LFSR; i )
//      begin : lfsr_gen
//         altera_emif_avl_tg_lfsr # (
//            .WIDTH     (LFSR_WIDTH),
//            .SEED      (SEED * (3 1) i)
//         ) lfsr_inst (
//            .clk       (clk),
//            .reset_n   (reset_n),
//            .enable    (enable),
//            .data      (lfsr_data[((i 1)*LFSR_WIDTH-1):(i*LFSR_WIDTH)])
//      end
//   endgenerate
   always_ff @(posedge clk or negedge reset_n)
   begin
      if (!reset_n) begin
         lfsr_data         <=  256'H00000000FFFFFFFF00000000FFFFFFFF00000000FFFFFFFF00000000FFFFFFFF;
      end else if (enable) begin
         lfsr_data         <=  ~lfsr_data;
      end
   end
Updated 11 months ago
Version 3.0
