Knowledge Base Article
How can I simulate the ASMI Intel FPGA IP with internal and external memory models when using the Intel® Arria® 10 and Intel Cyclone® 10 GX devices?
Description
For internal memory model use case, we currently only support simulation of the ASMI Intel FPGA IP in Intel® Arria® 10 and Intel Cyclone® 10 GX devices with the flash model for the EPCQL1024 serial configuration device.
Follow the steps in the Resolution section to perform the simulation with the internal EPCQL model (Note: This simulation was tested with Mentor Graphics* ModelSim* SE simulation software).
Resolution
  1. Create a simulation model for ASMI block and set the enable_sim parameter to true in file:
    <project directory>/<ASMIIP    name>/<altera_asmi_parallel_<quartus_version>>/<sim>/<ip_name>altera_asmi_parallel_<quartus_version>_<unique_ip_id>.v
  2. Create a testbench file with initialization of ASMI block as shown in the following example:
    <ip_name>_altera_asmi_parallel_<quartus_version>_<unique_ip_id> dut(
    .clkin          (clkin),          //          clkin.clk
    .fast_read      (fast_read),      //      fast_read.fast_read
    .rden           (rden),           //           rden.rden
    .addr           (addr),           //           addr.addr
    .read_status    (read_status),    //    read_status.read_status
    .write          (write),          //          write.write
    .datain         (datain),         //         datain.datain
    .sector_protect (sector_protect), // sector_protect.sector_protect
    .sector_erase   (sector_erase),   //   sector_erase.sector_erase
    .die_erase      (die_erase),      //      die_erase.die_erase
    .wren           (wren),           //           wren.wren
    .read_rdid      (read_rdid),      //      read_rdid.read_rdid
    .en4b_addr      (en4b_addr),      //      en4b_addr.en4b_addr
    .ex4b_addr      (ex4b_addr),      //      ex4b_addr.ex4b_addr
    .reset          (reset),          //          reset.reset
    .sce            (sce),            //            sce.sce
    .dataout        (dataout),        //        dataout.dataout
    .busy           (busy),           //           busy.busy
    .data_valid     (data_valid),     //     data_valid.data_valid
    .status_out     (status_out),     //     status_out.status_out
    .illegal_write  (illegal_write),  //  illegal_write.illegal_write
    .illegal_erase  (illegal_erase),  //  illegal_erase.illegal_erase
    .read_address   (read_address),   //   read_address.read_address
    .rdid_out       (rdid_out)        //       rdid_out.rdid_out
  1. Run simulation.
To simulate with an external memory model, follow these steps:
  1. Create a simulation model for ASMI block and set the enable_sim parameter to false in file:
    <project directory>/<ASMI IP name>/<altera_asmi_parallel_<quartus_version>>/<sim>/<ip_name>altera_asmi_parallel_<quartus_version>_<unique_ip_id>.v
  2. Create a testbench file with initialization of ASMI block (as shown in the previous code example):
  3. Create a wrapper for external memory
  4. In a simulation project, compile the following files for your working folder:
  •     flash simulation model
  •     asmi_sim_model design wrapper
  •     testbench file(s)
  1. Run simulation.
Updated 10 months ago
Version 2.0
