Knowledge Base Article
How can I generate the PLL Intel® FPGA IP using a script or the command line interface?
Description
To generate the PLL Intel® FPGA IP from the command line interface, the ip-generate utility can be used.
Resolution
The following is a simple command line example of the PLL Intel FPGA IP generation using ip-generate:
c:\altera\13.1\quartus\sopc_builder\bin>ip-generate --output-directory=<output directory>--file-set=<file set> --component-name=altera_pll --output-name=<desired instant name> --system-info=DEVICE_FAMILY="<Device family name>" --component-param=gui_reference_clock_frequency="<input reference clock>" --component-param=gui_output_clock_frequency0="<desired output clock frequency>" --component-param=gui_phase_shift0="<desired phase shift>" --component-param=gui_duty_cycle0="<desired duty cycle>"
For more options on ip-generate, run ip-generate --help in command line.
Updated 11 months ago
Version 3.0
