Knowledge Base Article
GLOBAL_SIGNAL assignments might be lost if you create a new project revision from an existing revision for Stratix IV
Description
Some GLOBAL_SIGNAL assignments might be lost if you create a new project revision from an existing revision.
Resolution
If the base revision contains GLOBAL_SIGNAL assignments, check the new revision for missing assignments.
Updated 11 months ago
Version 3.0
