Knowledge Base Article
For some MAX 10 device designs, the Fitter causes an abnormal exit during the Fitter stage when listen_to_nsleep_signal is set
Description
In the Quartus II software version 15.0, a legality check issue in the Fitter causes an abnormal exit during the Fitter stage when the listen_to_nsleep_signal parameter is explicitly set to true but the nsleep port is not connected.
This issue applies to designs targeting the MAX 10 ZB16/25/50 device only. The Quartus II software should generate a user error, but causes an abnormal exit instead.
You might encounter the abnormal exit if you use an input buffer atom, or Altera's general-purpose I/O (GPIO) Lite to construct your IP.
Resolution
There is no workaround. This issue will be fixed in a future software release.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
