Knowledge Base Article
Example Code Error in Nios II Processor Reference Handbook, Application Binary Interface Chapter
Description
In the Application Binary Interface chapter
of the Nios II Processor Reference Handbook, Example
7-3 (“Returned struct is Larger than 8 Bytes”) contains a typographical
error. *value should be replaced by &value.
Resolution
The correct code example is as follows:
void b(STRUCT *p_result, int i, int j)
*p_result = result;
void a(...)
STRUCT value;
b(&value, i, j);
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
