Knowledge Base Article
Errors (<number>):Could not allocate the following pins to any bank: - <number> pins at <voltage> mV" in the Early Power Estimator Intel® Stratix® 10
Description
Due to a problem with the Early Power Estimator (EPE) Intel® Stratix® 10 version 19.4 and earlier, you may see this error even if the total number of used pins in the IO tab is within the maximum GPIOs.
Resolution
You can ignore the error and this problem won’t affect your power estimation result.
You can see the correct maximum GPIOs in the respective Intel® Stratix® 10 product family overview below.
This problem has been fixed in Intel® FPGA Power and Thermal Calculator version 21.3.  Use Intel® FPGA Power and Thermal Calculator version 21.3 or newer instead of Early Power Estimator Intel® Stratix® 10.
Updated 11 months ago
Version 3.0
