Knowledge Base Article
Error(272006) Parameter IMPLEMENT_IN_LES can only be set to OFF for device family Intel® Stratix® 10
Description
In the Intel® Quartus® Prime Pro edition software version 20.3, when using the FIFO Intel® FPGA IP, you may see this error if doing a manual instantiation of the IP and setting the use_eab parameter to OFF.
Resolution
To work around this problem, set the use_eab parameter to ON.
Updated 11 months ago
Version 3.0
