Knowledge Base Article
Error(272006): MGL_INTERNAL_ERROR: Port <altera_syncram_instance_hierarchy> inst altera_syncram_impl1|dffe inst ecc_addr_reg|d has already been assigned
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2 and earlier, you might see this error message during compilation in the synthesis stage for Simple Dual Port RAM when using the following configurations:
· Parameter device_family = "Agilex"
· Parameter ram_block_type = "M20K"
· Parameter enable_ecc = "TRUE"
· Parameter address_aclr_b = "ACLEAR"
· Parameter outdata_reg_b = "CLOCK0/CLOCK1"
· Width x numwords is more than 20480 bits (more than 1 M20K used)
· No read enable signal is used
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition software version 21.4 and 22.2
Download and install the patches from the following links:
For Intel® Quartus® Prime Pro Edition Software version 21.4:
For Intel® Quartus® Prime Pro Edition Software version 22.2:
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 8 months ago
Version 3.0
