Knowledge Base Article
Error(22730): RAM Primitive "dut|dut|dcore|hptxs|hptxs_rx|tag_complete|wwr_ram|auto_generated|altera_syncram_impl1|ram_block2a0" parameter operation_mode value QUAD_PORT is no longer supported for the target device.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1. the following error will occur when enabling HPTXS in the L-tile and H-tile Avalon® Memorymapped Intel® FPGA IP for PCI Express* Design Example.
- Error(22730): RAM Primitive "dut|dut|dcore|hptxs|hptxs_rx|tag_complete|wwr_ram|auto_generated|altera_syncram_impl1|ram_block2a0" parameter operation_mode value QUAD_PORT is no longer supported for the target device
Resolution
To avoid the fitter error, add the following line to the quartus.ini present in the project directory:
skip_nd_sqp_power_temp_check=on
If you do not already have a quartus.ini file, use the text editor and create this file in your project directory, then add the above line.
This will allow you to compile without errors.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
