Knowledge Base Article
Error(210026): File <User directory>/<file name>.jic is corrupted
Description
You may see this error in the Intel® Quartus® Prime software version 19.1 when program .jic file that is generated user defined flash device using Quartus® Programmer.
Resolution
To work around this problem, you can use either one of the options:
Option 1: Store the defined flash XML at quartus/common/devinfo/programmer/xml directory, which is the default option.
Option 2: Store the XML and JIC files in the same directory.
This problem is fixed starting with Intel® Quartus® Prime Standard Software version 19.1 and Intel® Quartus® Prime Pro Edition Software version 19.2.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
