Knowledge Base Article
Error(19117): Programming failed on flash chip select 0 at address <address>
Description
You may see this error in Quartus® Programmer when programming a QSPI flash device attached to an Agilex® 7 FPGA device with a .JIC file, when the TCK frequency of the download cable is set to 24 MHz and if there is another device in the JTAG chain which has a maximum supported TCK frequency of less than 24 MHz.
For example, a MAX® 10 FPGA device that may be in the chain has a maximum TCK frequency specification of 20 MHz.
Resolution
To work around this issue, in the Quartus® Programmer Hardware settings, set the Hardware Frequency to a lower frequency (e.g. 16000000Hz) and uncheck the Auto-adjust frequency at chain scanning box.
Updated 5 months ago
