Knowledge Base Article
Error(13305): Verilog HDL error at altera_eth_tse.v(138): can't find port "system_pll_clk_link"
Description
When generating the TSE example design with the following settings:
Variant: 10/100/1000Mb Ethernet MAC with 1000BASE-X/SGMII 2XTBI PCS with F-Tile FGT Transceiver
Target Board: Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit
You might encounter a compilation error during the Support Logic Generation step:
Resolution
The error occurs due to incorrect IP core configuration while generating the example design for F-Tile. To resolve this issue, ensure the following configuration steps are followed:
  1. Use the correct Preset when generating the example design.
    • Library: 10/100/1000Mb Ethernet MAC with 1000BASE-X/SGMII 2XTBI PCS and PMA (Agilex F-Tile)
    • Using the preset ensures the IP core is properly configured for the target platform.
  2. In the Triple-Speed Ethernet IP Parameters tab:
    • Under PCS Options, enable:
      • Enable SGMII bridge
    • Under F-Tile FGT Transceiver Options, enable:
      • Enable F-Tile transceiver dynamic reconfiguration (System Clock Mode)
Updated 11 months ago
Version 3.0
