Knowledge Base Article
Error (XXXXX): Cannot generate Atom Netlist File because family Stratix® 10 FPGA is not installed
Description
Due to a problem in the FPGA SDK for OpenCL version 21.1, this error may be seen when compiling a Stratix® 10 OpenCL kernel using the import flow.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition software version 21.1. Download and install Patch 0.14cl from the files below.
This problem is fixed starting with the Quartus® Prime Pro Edition software version 21.2.
Updated 27 days ago
Version 5.0No CommentsBe the first to comment
