Knowledge Base Article
ERROR: UNRECOGNIZED ERROR CODE (-1001), Location: ../common/src/AOCLUtils/opencl.cpp:297, Query for number of platforms failed
Description
You may see the error above when running the host program using the Intel® FPGA SDK for OpenCL* compiler.
Resolution
To work around this problem, type the following command in a Linux shell as root
sudo cp $INTELFPGAOCLSDKROOT/Altera.icd /etc/OpenCL/vendors/
Updated 11 months ago
Version 4.0No CommentsBe the first to comment
