Knowledge Base Article
Error (suppressible): $MODEL_TECH/../intel/verilog/src/tenm_atoms.sv(...) (vopt-2732) Module parameter '...' not found for override.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4,  this error will be seen when using Questa*-Intel® FPGA Edition to simulate a design example that instantiates the PHY Lite for Parallel Interfaces Intel Agilex® FPGA IP.
Resolution
To work around this problem, perform the following steps:
  1. Open msim_setup.tcl file under .../sim/ed_sim/mentor folder.
  2. Modify the following command:
eval vsim -voptargs=+acc $elabcommand
to
eval vsim -suppress 2732 -voptargs=+acc $elabcommand
Additional Information
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
