Knowledge Base Article
Error: Received error code -42 on line 122 in host/src/OpenCL.c
Description
When you download "Multifunction Printer Error Diffusion" example design from the Website and compile it with a10soc_2ddr BSP, you might get the following error during runtime on the Arria® 10 SOC board.
Failed to initialize OpenCL environment.
Resolution
Two workaround the issue, please remove the line “CL_CONTEXT_COMPILER_MODE_ALTERA=3” in ~/init_opencl.sh and source ~/init_opencl.sh. Then run host again.
Updated 11 months ago
Version 3.0
