Knowledge Base Article
Error: native_10g_fechp_322_inst: The current value "continuous" for parameter "DFE adaptation mode" (rx_pma_dfe_adaptation_mode) is invalid. Possible valid values are: "".
Description
You may see the above error in the Intel® Arria® 10 device 1G/10GbE and 10GBASE-KR PHY IP Parameter Editor Message Pane when Hard PRBS support is enabled when using the Intel® Quartus® Prime software version 15.1.2.
Resolution
This is a known problem in the Intel® Quartus® Prime software version 15.1.2. To work around this, you can download and install the patch below
- Download the version 15.1.2 patch 2.16 for Windows (.exe)
- Download the version 15.1.2 patch 2.16 for Linux (.tar)
- Download the Readme for the Quartus II software version 15.1.2 patch 2.16 (.txt)
This problem has been fixed starting in v16.0 of the Intel® Quartus® Prime software.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
