Knowledge Base Article
Error: native_10g_322_ls_inst: The current value "" (10312.5) for parameter "Data rate" (set_data_rate) is invalid. Possible valid values are: "" (1000.0:8000.0).
Description
Due to a problem with the Intel® Arria® 10 Device Datasheet, you may see the above error in Intel® Quartus® Prime software version 17.0 during HDL generation for Arria® 10 1G/10GbE and 10GBASER-KR PHY in Arria® 10 automotive speed grade device even though the maximum data rate specified in the datasheet is 12.5Gbps. The maximum transceiver data rate should be 8Gbps for Arria® 10 automotive speed grade device.
Resolution
No plan to fix.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
