Knowledge Base Article
Error: $MODEL_TECH/../intel/verilog/src/mentor/twentynm_atoms_ncrypt.v(38): in protected region
Description
Due to a problem in the Quartus® Prime Standard Edition Software, you might see this error message when simulating the ASMI (Active Serial Memory Interface) Parallel IP for Arria® 10 FPGA devices. This is due to the simulation libraries for the ASMI Parallel IP is missing in the Quartus® Prime Standard Edition Software.
Resolution
To work around this problem, upgrade the design to the Quartus® Prime Pro Edition Software.
The simulation libraries for the ASMI Parallel IP are available in the Quartus® Prime Pro Edition Software.
This problem is not scheduled to be fixed in the Quartus® Prime Standard Edition Software.
Related IP Core
- ASMI Parallel IP
Updated 6 months ago
