Knowledge Base Article
Error Messages Shown when Nios II processor is Added in Qsys
Description
You might encounter the following error messages when the Nios II processor is added to a system with the Qsys software:
Error: nios2_qsys_0: "Reset vector memory" (resetSlave)
out of range
Error: nios2_qsys_0: "Exception vector memory" (exceptionSlave)
out of range
Error: nios2_qsys_0: Reset slave is not specified. Please select
the reset slave
Error: nios2_qsys_0: Exception slave is not specified. Please select
the exception slave
These error messages are to be expected, because no memory devices are connected to the Nios II processor. The error messages disappear when you assign memory devices to the Reset vector memory and Exception vector memory fields.
Resolution
No workaround is required.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
