Knowledge Base Article
Error importing a valid value. Field "Operation Mode" will be set to default value.
Description
Due to a problem in the Intel® FPGA Power and Thermal Calculator (PTC) version 21.3 and earlier, you may see that the Operation Mode field has an invalid import when you import the .qptc file. This problem only affects designs targeting Intel Agilex® devices.
Resolution
To work around this problem, manually change the setting for the Operation Mode field from Receiver and Transmitter FGT to Receiver and Transmitter FHT.
This problem is fixed starting with the Intel® FPGA Power and Thermal Calculator (PTC) version 21.4
Updated 11 months ago
Version 3.0
