Knowledge Base Article
Error: essai.xcvr_fpll_a10_0: Unable to compute a valid reference clock frequency given desired output frequency, selected pma width and mcbg clock division factor. Your selection of Bandwidth setting may also contribute to this issue.
Description
You may see this error in the Intel® Quartus® Prime Software when implementing a transceiver (XCVR) fractional PLL (fPLL) in Intel® Arria® 10 devices with both Enable downstream cascaded PLL and Operation Mode set to Feedback Compensation Bonding in the fPLL intellectual property (IP) GUI.
Resolution
To avoid this error, refer to the Intel® Arria® 10 Device Datasheet and ensure that the input frequency of the fPLL is within the minimum and maximum fCASC_PFD specification (Table 30) and the output frequency is equal to or above the Supported Output Frequency (Table 19).
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
