Knowledge Base Article
Error: Could not open afu_opencl_kernel.fit.rpt for reading
Description
When you compile OpenCL code for Intel® Programmable Acceleration Card with Intel® Arria® 10 GX FPGA, you may see the Error: Could not open afu_opencl_kernel.fit.rpt for reading. What’s more, you may see the following warning:
Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Warning (115005): Unlicensed IP: "PCIe SRIOV with 4-PFs and 2K-VFs(6AF7 00FB)"
Warning (115005): Unlicensed IP: "Low Latency 10Gbps Ethernet MAC(6AF7 0119)"
Warning (115005): Unlicensed IP: "Low Latency 40Gbps Ethernet MAC and PHY(6AF7 011B)"
Resolution
This is because Rush Creek DCP license expired 12/31/2019. A patch is available to fix this problem for the Intel® Quartus® Prime  software version 17.1.1. Download and install the patch from the appropriate link below.
Updated 4 months ago
Version 4.0
