Knowledge Base Article
Error: can't read "rp_generated_name": no such variable
Description
The error "Error: can't read "rp_generated_name": no such variable" will be observed when generating the F-Tile Avalon® Streaming Intel® FPGA IP for PCI Express* Design Example using the Intel® Quartus® Prime Pro Edition Software version 22.1.
The error is caused by attempting to generate the design example with the Example Design Files "Synthesis" option enabled but the "Simulation" option not enabled.
Resolution
To work around this problem ensure that both Simulation and Synthesis options are enabled before clicking the "Generate Example Design" button.
This problem has been fixed starting in version 22.3 of the Intel® Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
