Knowledge Base Article
Error: add_fileset_file: No such file "xxx" while executing "add_fileset_file $output_dir/altera_cpri_v6.ip OTHER PATH $tempdir/$output_dir/altera_cpri_v6.ip"
Description
Due to a problem with the CPRI Intel® FPGA IP, you may see the error message below when you open this IP and click button "Generate Example Design..." in Intel® Quartus® Prime Pro Edition 18.1 under Windows system.
"Error: add_fileset_file: No such file "xxx"    while executing"add_fileset_file $output_dir/altera_cpri_v6.ip OTHER PATH $tempdir/$output_dir/altera_cpri_v6.ip"    (procedure "components_generation_pro" line 11)    invoked from within"components_generation_pro $tempdir"    (procedure "components_generation" line 3)    invoked from within"components_generation $tempdir"    (procedure "testbench_proc" line 16)    invoked from within"testbench_proc cpri_ii_0_testbench"Error: Failed to generate example design testbench to: "xxx"
Resolution
This problem has been fixed starting with the Intel® Quartus® Prime Pro Edition software 19.1 .
Updated 11 months ago
Version 3.0
