Knowledge Base Article
Error (332000): can't read "local_pll_driver_core_clk": no such variable
Description
When you use LPDDR2 SDRAM Hard Memory Controller in Quartus® II software version 13.0SP1, you will see the following fitter errors when you compile your project.
while executing
"set_min_delay -from -to 0.500"
("foreach" body line 504)
invoked from within
"foreach { inst } {
if { [ info exists pins ] } {
# Clean-up stale content
unset pins
array set pins $<variation name>_p0_ddr_db()
(file "<variation name>/<variation name>_p0.sdc" line 159)
The reason for this issue is that <variation name>_p0.sdc doesn’t create “local_pll_driver_core_clk” since it doesn’t know the clock for the driver and MPFE ports in customer’s user logic.
But the error will not appear if you compile the example project generated by IP Megawizard because in the example project, the node name is known and then the <variation name>_example_if0_p0.sdc file will create “local_pll_driver_core_clk”.
Resolution
The workround for this issue:
1. Create a new sdc file such as sdc1.sdc and create the clock constraint for the clock used for the driver and MPFE ports. Set the clock name as “user_driver_clock”.
2. Add sdc1.sdc into project and place it in the order before <variation name>_p0.qip in QSF.
3. Change the following line in the <variation name>_p0.sdc file
Change From
To
set_min_delay -from [get_clocks { user_driver_clock }] -to 0.500
