Knowledge Base Article
Error (213009): File name "output_files/afu_import.green_region.pmsf" does not exist or can't be read
Description
Due to a problem in the Intel® FPGA Add-on for oneAPI Base Toolkit software version beta01, all FPGA hardware compiles fail for designs targeting an Intel® Programmable Acceleration Card with the Intel® Arria® 10 GX FPGA. The compilation fails due to an internal license expired on December 31st, 2019.
Resolution
To work around this problem in the Intel® FPGA Add-on for oneAPI Base Toolkit software version beta01, download the patch and install it using follow these steps:
1.      Untar oneAPI_fpga_addon_beta01_patch01.tar
2.      Cd <directory where you untar above file>
3.      Run
    chmod u x QuartusProSetup-17.1.1-Patch-1.03dcp-linux.run
4.      Run
sudo ./QuartusProSetup-17.1.1-Patch-1.03dcp-linux.run --mode unattended --installdir "/opt/intel/inteloneapi/intelfpgadpcpp/2021.1-beta01/QuartusPrimePro/17.1.1" --skip_registration 1 --accept_eula 1
Updated 4 months ago
Version 4.0
