Knowledge Base Article
Error (209053): Unexpected error in JTAG server --error code 44
Description
You may see this error message when configuring a Stratix® V device using JTAG configuration scheme if all the following conditions are met:
  • Operating system: Windows 10
  • jtagserver version: 19.1 Standard Edition or later
  • Download cable: Intel® FPGA Download Cable
Resolution
To work around this problem, use jtagserver version 18.1 Standard Edition instead.  The jtagserver version 18.1 Standard Edition is installed when the Intel® Quartus® Prime Standard Edition Software v18.1 or Intel Quartus Prime Standard Edition Software v18.1 Programmer and Tools is installed.
Use the following steps to check the jtagserver version:
  1. Open a Command Prompt window.
  2. Execute the following command:
    jtagserver -v
If the jtagserver version is not Standard Edition v18.1, use the following steps:
  2. Go to
    <Intel® Quartus® Prime 18.1 Standard Edition install directory>\quartus\bin64
    or
    <Intel® Quartus® Prime 18.1 Standard Edition Programmer and Tools install directory>\qprogrammer\bin64
  3. Execute the following command:
    qreg.exe --force --setqdir --jtag
Updated 11 months ago
Version 3.0
