Knowledge Base Article
Error (209014): CONF_DONE failed to go high in device <number>
Description
Due to an issue in the Quartus® Prime software version 16.1.1 and earlier, you may observe this error in the Quartus Prime programmer when programming MAX® 10 devices with date code 1625 and onwards, using the following sequence:
Full-chip erase --> SOF configuration --> Power cycle/pulse nCONFIG --> SOF/POF programming.
Resolution
This issue is fixed in Quartus Prime software version 16.1.2.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
