Knowledge Base Article
Error (20783): Open Drain option is set to 'ON' for pin [pin name], but the setting is not supported by I/O standard 1.2‑V. File: [location]
Description
Due to a known issue in Quartus® Prime Pro Edition version 25.3.1, designs targeting Agilex® 7 FPGA M‑Series devices that enable the open‑drain feature on bidirectional pins may produce the following error during compilation:
Resolution
To fix this problem in Quartus® Prime Pro software version 25.3.1, install patch 1.13 below for the correct OS (Operating System)
  • Linux: quartus-25.3.1-1.13-linux.run
  • Windows: quartus-25.3.1-1.13-windows.exe
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1
Updated 4 months ago
Version 4.0
