Knowledge Base Article
Error (18108): Can't place multiple pins assigned to pin location Pin_XXX (IOPAD_X224_Y12_N61), Info (18109): Pin ~ALTERA_AVST_DATA0~ is assigned to pin location Pin_XXX (IOPAD_X224_Y12_N61)
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 18.0 and earlier, you may see this error when implementing a Partial Reconfiguration design using the AVST (Avalon-ST) configuration pins.
Resolution
This error is fixed beginning with Intel Quartus Prime Pro Edition software version 18.0 Update 1.
Updated 11 months ago
Version 3.0
