Knowledge Base Article
Error (178004): Could not find location for Clock Divider that enable routing of bonding clock lines
Description
You may see the following Quartus® II Fitter error with Stratix® V GX and Arria® V GX devices if you attempt to place logical channel 0 of a bonded transceiver PHY IP on a transceiver channel that does not have access to a central clock divider block.
"Error (178004): Could not find location for Clock Divider that enable routing of bonding clock lines"
On Stratix V and Arria V transceiver devices, only physical channels 1 and 4 within a transceiver block can access a central clock divider.
Resolution
To work around this problem, assign logical channel 0 of the PHY IP to physical channel 1 or 4 of the transceiver bank.
This information will be updated in a future version of the Altera Transceiver PHY IP Core User Guide.
This limitation was removed in version 11.1.1 of the Quartus® II software.
Updated 11 months ago
Version 3.0
