Knowledge Base Article
Error (16045): Instance "ccip_std_afu|bsp_logic_inst|board_inst" instantiates undefined entity "board" File
Description
When compiling an OpenCL™ design using the a10_pac board support package (BSP), you may get an error similar to the following.
If this error appears, the environment variable ALTERAOCLSDKROOT may not be set to the correct directory.
Resolution
To work around this problem, set the environment variable ALTERAOCLSDKROOT using the following command:
   export ALTERAOCLSDKROOT=$INTELFPGAOCLSDKROOT
This command requirement is included in the latest version of the OpenCL™ on Intel®  Programmable Acceleration Card with Intel Arria® 10 GX FPGA Quick Start User Guide at the link below.
https://www.intel.com/content/www/us/en/programmable/documentation/fvf1521490619217.html#cgy1522340402284
This command requirement is scheduled to be removed in a future release of the Intel® Acceleration Stack for Intel Xeon® CPU with FPGAs.
Updated 11 months ago
Version 3.0
