Knowledge Base Article
Error (14394):  Verilog HDL error at <project_name>_auto_tiles.sv(<line number>) : <ip instance_name> is not declared under the prefix "<top_level_wrapper_name>"
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2 and earlier, you might see this error when your HDL code has a generated block to choose between the instantiation of a design targeted to Agilex™ 7 F-Tile device and other supported device.
If the 'generate if' blocks are not labeled, the cross-module references into unlabelled generate blocks throw an error.
For example
generate
  if(Agilex == 0)
  begin
  end
else
  begin
end
endgenerate
This error occurs at the Analysis and Synthesis stage.
Resolution
To work around this problem, define a label for each 'if and else' statement in Verilog HDL and a 'generate' statement in VHDL. For example, if a design is targeted to choose between the Agilex™ F-Tile device and Arria® 10 device, then the instantiation can be chosen using generate statement in Verilog HDL and VHDL as follows.
Verilog HDL
  generate
    if(Agilex == 0)
    begin : label1_notfor_AG
    end
  else
    begin : label2_for_AG
  end
  endgenerate
VHDL
  label:
  if cond1 generate
  elsif cond2 generate
  else generate
  end generate label;
Updated 11 months ago
Version 3.0
