Knowledge Base Article
Error (12857): HIP reset pin "perst" is locked to "PIN_<your_PERST_ pin location>", which is not legal.
Description
Due to a problem in Quartus® II software version 13.1, you will see this error if you incorrectly hook up the DDR3 pins or have unconnected pins in the DDR portion of the device. If you have such incorrect DDR pin connections you will see this error even if your PERST is on a legal and correct pin location.Resolution
Correct the DDR pin errors.
This problem is fixed in Quartus II software version 14.0.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
