Knowledge Base Article
Error (12341): The input pin has a HCSL I/O standard, but the selected device does not support input pin operation with a HCSL I/O standard.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software versions 21.1 and 21.2, the following error message is observed during the fitter stage when using the HCSL I/O standard for the reference clock input pins for the R-Tile Avalon® Streaming Intel® FPGA IP for PCI Express:
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition software versions 21.1 and 21.2, set the R-Tile Avalon® Streaming Intel® FPGA IP for PCI Express reference clock input as the CML I/O standard. The reference clock driving these clock pins must be HCSL, as per the PCI Express Base Specification and the Intel Agilex® Device Family Pin Connection Guidelines.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
