Knowledge Base Article
Entity "cpriphy_ftile_wrapper" instantiates undefined entity "ex_24G_simple_model". This may cause the generated IP information to be incomplete.
Description
The simplified IP core model in simulation (Support 24G non-FEC only) option supports:
- System PLL frequency: 805.664062 MHz
- Enable CDR clock output not selected
- PMA reference frequency: 184.32MHz
- Select design: Single instance of IP core
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4 and earlier, other configurations than the listed when the simplified IP core model in simulation (Support 24G non-FEC only) option is selected will pass IP example design generation without errors, however the Quartus® compilation will fail with errors pointing to the illegal configuration of the listed items.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 24.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
