Knowledge Base Article
Enable Avalon-MM Byte-Enable Signal Option Not Functional for RLDRAM II Controller with UniPHY
Description
The Enable Avalon-MM byte-enable signal option available on the Controller. Settings tab in the parameter editor does not function.
Resolution
There is no workaround for this issue.
Updated 1 month ago
Version 2.0
