Knowledge Base Article
EMIF Maximum Frequency Specification Update for Stratix V
Description
This problem affects DDR2 and DDR3 products.
DDR2 and DDR3 interfaces on Stratix V devices may have difficulty achieving timing closure at certain maximum frequencies.
Resolution
The workaround for this issue is to apply the appropriate solution for your configuration as described below:
- For Stratix V, -C1/-C2 speed grade device interfacing with a DDR2 SDRAM DIMM in a quad-rank, dual-slot configuration, using soft controller at half-rate, and a frequency specification of 400 MHz: Upgrade the 400 MHz DDR2 SDRAM component to a 533 MHz DDR2 SDRAM component to achieve the specified maximum frequency.
- For Stratix V, -C1/-C2 speed grade device interfacing with a DDR2 SDRAM component in a 2-chip select configuration, using soft controller at half-rate, and a frequency specification of 400 MHz: Upgrade the 400 MHz DDR2 SDRAM component to a 533 MHz DDR2 SDRAM component to achieve the specified maximum frequency.
This issue will not be fixed.
The solutions for maximum frequency specifications will be updated in a future version of the External Memory Interface Spec Estimator.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
