Knowledge Base Article
Does the TOD_MASTER_156_25MHz_P signal on the Agilex® 7 FPGA M-Series require external bias circuitry when AC-coupled?
Description
The Agilex® 7 FPGA M-Series 039 production-board design uses the TOD_MASTER_156_25MHz_P signal with AC coupling. There is no information whether this AC-coupled interface requires additional external bias circuitry for correct signal transmission and operation.
Resolution
The reference implementation shows TOD_MASTER_156_25MHz_P with AC coupling and with external bias circuitry. Follow the implementation shown in the AN 555: True Differential Signaling Termination and Biasing for Agilex® 7 FPGA M-Series, Agilex® 5 FPGAs, and Agilex® 3 FPGAs
Updated 2 months ago
