Knowledge Base Article
Does Stratix® 10 support Serial Vector File (SVF) file for configuration?
Description
Yes. Stratix® 10 support Serial Vector File (SVF) file for configuration in Quartus® Prime Pro.
However, SVF file support will be discontinued in a future versions.
For SDM-based devices, SVF file configuration could take more than 2 minutes to be completed compare to JTAG configuration with Quartus® Programmer or JAM/JBC method that just needs a few seconds to be completed.
Thus, it is not realistic to use SVF file to configure as it takes a longer time.
Resolution
To work around this problem, migrate to JAM/JBC format instead of SVF.
Updated 2 months ago
