Knowledge Base Article
DisplayPort Arria 10 Design Example Fails Compilation
Description
The Arria 10 design example for the DisplayPort IP core fails to compile. This issue is caused by the end of line (EOL) ASCII symbol in the example.sdc file.
Resolution
For Linux users, you can work around this issue by running the dos2unix command to remove the EOL symbol from the example.sdc file.
This issue is fixed in version 15.1 Update 2 of the DisplayPort IP core.
Updated 11 months ago
Version 3.0
