Knowledge Base Article
Designs Targeting Stratix V Fail to Generate Simulation Model
Description
Designs that use the SDI MegaCore function targeting a Stratix V device fail to generate a simulation model in MegaWizard Plug-In Manager.
Resolution
To generate a simulation model for your Stratix V design, follow these steps:
  1. In the Quartus II software, create a project and launch the MegaWizard Plug-In Manager
  2. Create a new custom megafunction variation, and select the desired SDI configuration
  3. On the EDA tab, make sure to turn off Generate simulation model
  4. Click OK
  5. In a command terminal, change the directory to the project folder to generate xcvr and sdi-library folders
  6. Run the quartus_map script as follows:
Verilog Example: quartus_map <proj_name>.v --simgen --simgen_parameter="CBX_HDL_LANGUAGE=Verilog" --family="Stratix V" VHDL Example: quartus_map <proj_name>.vhd --simgen --simgen_parameter="CBX_HDL_LANGUAGE=Vhdl" --family="Stratix V"The <proj_name>.vo or vho file gets generated at the project directory.
Updated 11 months ago
Version 3.0
