Knowledge Base Article
Default tCCD for LPDDR2 Devices Hard Codes to 2 Cycles
Description
This problem affects LPDDR2 products.
This issue applies to LPDDR2 interfaces, when an LPDDR2-S2 memory device is used. Generated example designs always set tCCD=2 cycles for LPDDR2 devices, but the minimum tCCD supported for LPDDR2-S2 is 1 cycle. Having tCCD=1 for LPDDR2-S2 devices may impact design performance.
Resolution
The workarounds for this issue are described below.
For designs using the High Performance Controller II (HPCII):
  1. In a text editor, open the file /dut_example_design/example_project/dut_example/submodules/ *_example_if0_c0.v.
  2. Search for .CFG_TCCD (2) and change it to .CFG_TCCD (1).
For designs using the hard memory controller:
  1. In a text editor, open the file /dut_example_design/example_project/dut_example/submodules/ *_example_if0.v.
  2. Search for .ENUM_MEM_IF_TCCD (“TCCD_2”) and change it to .ENUM_MEM_IF_TCCD (“TCCD_1”).
This issue will be fixed in a future version.
Updated 11 months ago
Version 3.0
